This message indicates that an attempt to get the port instance value for an MLAG from VSM has failed.
On dual-MSM systems try failing over to the backup MSM. Stackables or single MSM systems may require a reboot to correct the problem. If the issue persists, please escalate to engineering.
Error
Unable to get local port instance for MLAG %mlag%, Error = %err%
| Name | Type |
| mlag | uInt16 |
| err | sInt |
